99 Dakota 4x4 Front axle
Old Oct 16, 2009 | 11:26 AM
rckt64's Avatar
rckt64
Default 99 Dakota 4x4 Front axle
I don't know what axle is in this truck. Can someone fill me in?
I took off the cover and didn't notice any numbers. I got issues with it. With the front shaft off , if you grab the yoke and turn it hard to the right there is some noise like a little slip before it grabs. Yoke has a little play when wiggled. Looking in the gearbox, the gears look ok I don't see any real wear on the gears. Even the pinion attached to the yoke looks like it is ok. Could the problem just be the bearing that holds the yoke?
I do need to know what case this is first. What were the options on the 99 dakota. Mine has the V6.
Old Oct 16, 2009 | 11:23 PM
primus454's Avatar
primus454
Generic crap IFS lol...Mine has little bit of play and dribbles oil. I'm not too worried about it for the time being.
Old Oct 17, 2009 | 02:24 AM
Crazy4x4RT's Avatar
Crazy4x4RT
In 99 it was an AMC 35. You can look by make here. http://www.ringpinion.com/
