need some help with motor build
Old Oct 20, 2009 | 10:48 PM
lightle740's Avatar
lightle740
Default need some help with motor build
Hey everyone I appreciate any help you guys can give me, I got ahold of a 5.2 for my dakota but it needs rebuilt and I am having some trouble figuring out how to get to my desired result. I want to get this motor to about 350 hp and I need help deciding on heads and also which cam is going to work best with them and then injectors and basically all kinds of nonsense. I'm trying to get this stuff ironed out so I can start purchasing everything I need. Thank you for any advice you can give I'm a noob with mopar.
Old Oct 20, 2009 | 11:16 PM
magnethead's Avatar
magnethead
5.2 = 318 cubic inch. long lists of upgrades if you search google
Old Oct 21, 2009 | 02:16 AM
rtdakota2001's Avatar
rtdakota2001
do you want 350 at the flywheel or at the wheels? theres a huge difference in the way i would go about the build based on that answer.
Old Oct 21, 2009 | 09:16 PM
primus454's Avatar
primus454
The stock heads should do fine, just get the valves worked on. As for the easiest HP gain, do a 390 stroker
Old Oct 21, 2009 | 09:51 PM
bpark8824's Avatar
bpark8824
1.7's RR, LT's, Cam, M1, heads, bore & stroke.... the options are endless.
Or s/c'ed...
Old Oct 22, 2009 | 01:17 AM
rtdakota2001
the cheapest and fastest way to make power is from the bottle. its a tricky game though, go too far, and you have a nice paperweight, dont go far enough..... and well, you dont go fast enough. haha
