Problem w/ Anti-slip Differiential
Old Nov 2, 2009 | 01:27 PM
dodgebrandon'00's Avatar
dodgebrandon'00
Question Problem w/ Anti-slip Differiential
Recently I took my 2000 Dodge Dakota truck to the Dodge Dealership to repair a noise coming from my rear axle. The Dealership called back and gave me an estimate of $1,850 to completely rebuild my failed rain gear and pinons , plus side and carrier bearings inside the axle housing. I would love to repair this, but cannot afford it.
Can I simply have the anti-slip differential fluid replaced on this rear axle and continue to drive my vehicle without use of the Anti-Slip Differiential feature?? Any advice is extremely helpful!! Thank you in advance.
Old Nov 2, 2009 | 01:47 PM
dbilik's Avatar
dbilik
Cheapest option to repair this might be to find a new axle somewhere, junk yeard or craigslist, and swap the whole thing out. Maybe even upgrade to a better axle depending on what you had. As for the anti-slip, you could hunt for a new one with it.
Old Nov 2, 2009 | 11:33 PM
Independentfool's Avatar
Independentfool
the LSD is constant. there is no turning it on or off.
swapping out for a j/y rear end may be your cheapest fix. make sure the gear ratios are the same when/if you do this.
Old Nov 3, 2009 | 09:36 AM
TheePlaymaker's Avatar
TheePlaymaker
the stock units suck find a good shop not the dealer and get them to replace it with something that's not factory. I paid $700 to get a really really good LSD with everything replaced and labor in mine. It grips so much better than the broken crappy stock one It had in there.
Old Nov 3, 2009 | 09:37 AM
TheePlaymaker
and i think i drove on my broken one for a while but if it completley goes out you won't be happy so I would say to get it fixed somewhere else like i said. Have them fill it back up and hunt around for a shop.
