T-case shifter extension
Old Nov 5, 2009 | 05:41 AM
dodgeheller99's Avatar
dodgeheller99
Default T-case shifter extension
im sure a big part of it are my junk tires, but even when it is moist out my rear tires just spin and i have to reach WAY down to shift into 4HI till i hit second gear... this got old so we decided to take some threaded rod and a coupler and extend the shifter... the bolt is 10mmx1.5 oddly enough the nut fit perfect on the threaded rod, but the coupler did not like the threads on shifter so we just kinda crammed it on. took some measurements then bent the threaded rod with the vice and torch. and tack welded it to the coupler so it wouldnt swing around.. this is the result
this is all the way down in 4LO
Old Nov 5, 2009 | 07:17 PM
RoaminGnome's Avatar
RoaminGnome
lol looks a lil goofy but MUCH easier to get to. Looks like a success!
Old Nov 5, 2009 | 07:59 PM
CSCustomCars's Avatar
CSCustomCars
It does look pretty good. I say either paint the extension black or cover it with a silicone hose or something to make it look nicer.
Old Nov 5, 2009 | 10:59 PM
beefjerky's Avatar
beefjerky
I wish I could make my tires spin. I have to be in gravel/ice/super wet smooth pavement to make my 4 banger spin one rear tire lol
Old Nov 6, 2009 | 08:20 PM
RoaminGnome
I agree you need to paint it or put a covering on it of some sort. Tho now you got me thinking of doing this lol
Old Nov 8, 2009 | 07:54 PM
dodgeheller99
it was really simple took no more then an hour even with the little snags, also i just removed stock *** and put a grenade on it haha ... surprisingly it doent get in the way at all cause when its in 2hi the *** is about 3/4 from the dash.. cept it blocks my power outlet but i dont care cause i ran another one to my floor tray. thanks for you imputs!
Old Nov 8, 2009 | 09:56 PM
RoaminGnome
Do we get pics of this grenade?
Old Nov 9, 2009 | 01:24 AM
rtdakota2001's Avatar
rtdakota2001
his truck it turning into a novelty store. truck nuts, 8 ball cig lighter, grenade shifter, spinning air fresheners...
