removing back windows
Old Nov 14, 2009 | 10:51 PM
moparman_2004's Avatar
moparman_2004
Default removing back windows
i was trying to remove a slider the other day at the wrecking yard and finally got the piano wire in and started sawing and got about 6in in 20 min and the whole back window shattered it sucked but whats the easiest was to remove them cause i dont want to break another one even thou there only $9
Old Nov 16, 2009 | 08:36 AM
NowADodgeMan's Avatar
NowADodgeMan
When I bought my 2001 in Feb. the rear window leaked. The used car dealer sent me to a professional glass installer to have the old one replaced. As I watched them do the work, it became apparent that the only way to remove it is to break it. The professionals spent about an hour & a half trying to get it out before they decided to break it out. I don't know if you can get them out with out breaking them because of the way they are installed. My require a dealer w/ special tools. Sorry.
Old Nov 16, 2009 | 01:07 PM
moparman_2004
ya i just dont want to go to those extrems to remove a window
Old Nov 16, 2009 | 10:14 PM
SH0K0TA's Avatar
SH0K0TA
the rear windows can be removed without breaking them. i have a solid one i'ma be puttin on the truck soon in place of the slider.
pretty much it takes two ppl, but you gotta pry one top corner, then the other and work down the sides.
the bottom corners have the press in plastic things, you can see them if you take off the interior stuff.
once the sides are off, start at one side and slowly move towards the other and pry the window out. have your buddy hold the side thats already been pried out.
.... it takes awhile but it can be done
