Transmission (I think)
Old Nov 23, 2009 | 02:33 PM
oakey134's Avatar
oakey134
Originally Posted by Josh Abels
if your saying like it feels like your truck shifts into neutral then power suddenly comes back my truck does the same, its dodge lag same thing they r talking about above,
revs go real high, then the stall/neutral thing happens, then power comes back?
So are you saying I don't have a problem and this is typical.
Old Nov 23, 2009 | 05:25 PM
Josh Abels's Avatar
Josh Abels
if your getting that thing i was talking about then i believe so
Old Nov 23, 2009 | 07:18 PM
oakey134's Avatar
oakey134
Great, appreciate everyones response.
Old Nov 23, 2009 | 07:28 PM
magnethead's Avatar
magnethead
yes, I meant after. I would say what you're experiencing is "normal", but not "optimal". But that's because DC can't design or build modern transmissions for $#%^.
Old Nov 23, 2009 | 08:13 PM
jorgholio's Avatar
jorgholio
Default Mine does the same.....
I've had my 04 dakota 4x4 since new and it does the same on occaison. I dropped the oil and filter in the tranny about 2 years ago and I noticed that it didnt make a difference. Still does it once in a while, about once month since I've owned it.
Something to watch, after about 125,000 your water pump will crap its pants with no warning, first time being broken down helpless. So simple to change if you have one on hand.
