Some quick questions
Old Nov 24, 2009 | 04:14 AM
c_ryman19's Avatar
c_ryman19
Default Some quick questions
i have a 97 dakota with 318 harness and ecu. i know aguy with a built 318 out of a 92 dodge 4x4 full size truck. would this motor fitn my truck? im sure some of the wires are different but whick ones? like what do i need to do to make it work?
Old Nov 24, 2009 | 08:12 PM
c_ryman19's Avatar
c_ryman19
is there anyone who can help? also will the tranny from the 92 dodge go in my truck? i need a tranny for it but i was told only tranny that will work is one from a 97 dakota
Old Nov 24, 2009 | 08:17 PM
95_318SLT's Avatar
95_318SLT
If you use your sensors and intake manifold on the motor it will work just fine. The '92's intake manifold will have an EGR valve and yours does not. Of course, you can always make a little plate to block that off on the '92 manifold.
The transmission is another issue. You have the 46re behind your 318, the '92 has the 46rh. The difference is the governor valve in yours is electronically controlled and the gov valve in the '92 is hydraulically controlled. The 46rh will function normally, but your computer will throw codes without that electronic governor valve plugged in. If its your only option, you can do it, but you're better off looking for a 46re.
Old Nov 24, 2009 | 10:05 PM
c_ryman19's Avatar
c_ryman19
i dont have a motor or trans in my truck. all i have is the truck. i had a v6 in it and i sold th v6 and trans but i have a harness and ecufrom a 97 with 318 so im good there. i will pry just get the motor from the guy. what do you mean my sensors? i can make a plate for the egr valve. i guess i just need to know about the sensors
Old Nov 24, 2009 | 10:09 PM
c_ryman19's Avatar
c_ryman19
dont know if it will make a difference but i do have a running 318 and trans from a 98 jeep cherokee. would the intake manifold maybe work from that? also what about that trans?
Old Nov 24, 2009 | 11:31 PM
95_318SLT's Avatar
95_318SLT
IIRC, the jeep's transmission has the starter on the opposite side of the bellhousing, and the engine has different mounts. The motor itself will work fine if you get the correct mounts (assuming I'm right about them being wrong).
As for the sensors... I'm talking about the ECT, IAT, IAC, TPS, MAP, CrPS and CaPS. All the connectors changed between OBDI and OBDII.
Old Nov 26, 2009 | 08:58 AM
c_ryman19's Avatar
c_ryman19
i know that the motor wont fit. only through a 97 jeep motor will fit from what i was told and read. the starter is on the opposite side of the block. i didnt know about the trans
Old Nov 29, 2009 | 01:18 PM
c_ryman19's Avatar
c_ryman19
ttt..
Old Nov 29, 2009 | 02:16 PM
95_318SLT's Avatar
95_318SLT
The jeep, dodge and chrysler magnum blocks are all the same and have been since '92 (or '93 for the 360). There were slight differences in intake manifolds depending on whether or not it had an egr valve, and there were probably differences in the motor mounts depending on what it is in. The OBDII ('96+) sensors have different connectors than the OBDI ('92-'95) sensors. The starter does not bolt to the block, it bolts to the transmission's bellhousing, and from what I've heard/read, is on the opposite side of the bellhousing on the jeeps (pass. side instread of driver's side).
I don't know where you read or who told you that the motor won't fit, but I'm telling you it will fit as long as you don't mind replacing a few small parts.
Old Nov 29, 2009 | 03:35 PM
c_ryman19's Avatar
c_ryman19
do you happen to know what small parts i would need to change. also one other thing is what vehicles could i use a transmission from? i need atrans now that i have a motor. thanks man for all the help
