Strange grinding noise!
Old Nov 30, 2009 | 12:17 PM
99DakotaFTW's Avatar
99DakotaFTW
Default Strange grinding noise!
I own a 1999 Dakota Sport 4x4 with the 5.2L V8 engine. Every time i spin my tires even if not on purpose, i hear a somewhat loud grinding noise. it sure doesnt sounds healthy so i'm wondering what could be wrong with it. i would like a little information on it before i decide to take it in and spend money. thanks.
Old Nov 30, 2009 | 03:37 PM
moparman_2004's Avatar
moparman_2004
bearings??? where is it coming from the diff or the outside can you tell
Old Dec 3, 2009 | 12:51 AM
99DakotaFTW
im not too sure exactly where but the bearings could be right cuz it sounds like something is loose and rattling around when the tires are normal not spinning
Old Dec 3, 2009 | 11:51 AM
varsis's Avatar
varsis
Check the Pinion bearing, and the wheel bearings on the rear axle. Pinion should be easy to check just by pushing on it by hand, the wheels, just lift it off the ground and push on it side to side if they move bearing is shot...
