Time for some noise...
Old Nov 30, 2009 | 02:09 PM
jamoka3's Avatar
jamoka3
Talking Time for some noise...
Looking for a nice exhaust system up grade.
I'm running with the 3.9l v6, its a 4x4 extended cab.
I was looking at the Magnaflow cat back system, and i wanted to run the high flow magnaflow cat too, but what high flow cat will bolt right up to the stock down pipe?
Is there a aftermarket system that sells a cat and cat back together?
any suggestions?
Old Nov 30, 2009 | 11:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Go to the magnaflow website and see if they have a kit.
Old Nov 30, 2009 | 11:43 PM
primus454's Avatar
primus454
First thing is to get a v8
Old Dec 2, 2009 | 10:22 PM
jamoka3's Avatar
jamoka3
OK, well any v6 guys out there with any suggestions?
Old Dec 2, 2009 | 10:35 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
ebay. they have good cheap kits. all depends on your choice of muffler. i have the flowmaster super 44. but i also have the 3.7l v6, not the 3.9l v6.
Old Dec 2, 2009 | 10:39 PM
Josh Abels's Avatar
Josh Abels
ive got the same kit as tamcnally on the 4.7L v8 and its awesome
Old Dec 2, 2009 | 10:44 PM
jamoka3's Avatar
jamoka3
being I'm extended cab and with a longer wheel base.... will the same kits fit?
or do i need to order a certain length?
Old Dec 2, 2009 | 10:47 PM
Josh Abels's Avatar
Josh Abels
the kits on ebay come with a extension pipe and it also depends where you cut you pipe inbetween the cat and muffler, then it all clamps on fairly simple if you've got a air grinder
Old Dec 2, 2009 | 10:51 PM
Josh Abels's Avatar
Josh Abels
this is the kit ive got spring the extra money and get mandrel bent pipes if u do this
http://cgi.ebay.com/ebaymotors/Dodge...Q5fAccessories
Old Dec 2, 2009 | 11:00 PM
jamoka3's Avatar
jamoka3
yeah thats a nice looking set up, any fitmeit issues? like around spare or over rear axel?
also I wanted to up grade my cat too, cherry bomb, or magnaflow? any idea what size?
