questions any help welcome
Hi i have a dodge dakota V8 4.7l year 2000 i have 35" tires on it and i also have a superchips programer . The car is driven on 95 octane gas .
I was wondering if anyone has tried the E3 spark plug . Is it worth the money ?
I also need to change my front wheel bearings , I have to change the whole wheel hub. I was wondering if there is a wheel hub available that I could get in which I can only have to change the bearing not the whole hub the next time the bearing is needs to be changed . I would also like to hear from you if can give me any advise on how to get better fuel mileage .
thanks.
thanks.
you're gonna have to change the hub its the only way to do it, sucks but thats the design,
i've seen that the E3s do make a difference,
and you really arent gonna find many ways to increase your milage,i've heard that using forced induction can help if you arent running a lot of boost.. but then thats just what i've heard
Trending Topics
Thanks you guys for answering , I think that i will stick with the normal spark plugs. but what do you guys prefer champion or ngk?
Iam getting 18-20 liters per 100km. not sure what that is in mpg.
