2002 4 wheel drive lower ball joints question
Old Dec 12, 2009 | 05:50 PM
wszetela's Avatar
wszetela
Question 2002 4 wheel drive lower ball joints question
The problem is that on the ball joints that I purchased (MOOG) have the cir clip/o ring clip w/ zurich fitting....I have no access to the top to where these would work...Its capped off. I see on the other threads something about grinding down 3 rivets....I don't think this is the same thing.....Were there models that needed the whole arm replaced because I cant find any part without the clip or the zurich fitting? I looked for 01, 03 years and all three years call for same part....What im I missing????
Thanks
2002 Dakota Air-raid flow master
93000
Old Dec 12, 2009 | 06:05 PM
batman13's Avatar
batman13
as i remember on the 4x4s the top cap needs removed (i/e cut off) then the lower balljoint is pressed out,
the rivets are on the 2wd balljoints
keep in mind i have a 2wd, im speaking from memory so anybody with a 4x4 dal may chime in
Old Dec 12, 2009 | 06:55 PM
wszetela's Avatar
wszetela
I figured the rivets were on the 2 wheel...I have one of those also. these new ball joints came with the clips so I wander if they will even work....Anyone with a 4by replaced these before????? Thanks for the last reply!
Old Dec 12, 2009 | 08:36 PM
bpark8824's Avatar
bpark8824
The tops are bolted in and a piece of cake to replace.
The lower ones are little harder, as they are press in. You can heat them up and use a 10lb sledge if you don't have access to a press. Put the new ones in the freezer so they go in a little easier. But make sure when you put the new one the greese fitting is facing forward or you'll never be able to get to it.
Old Dec 13, 2009 | 12:05 PM
wszetela's Avatar
wszetela
My problem is that this is no access to the top of the fitting.....I have a feel I will need to grind the top off if I want to use the zurick fitting....Im waiting to see if anyone else has had this issue. Thanks for your input.
