1998 Dodge Dakota Stalling when warm no code
I have a 1998 Dodge Dakota that keeps stalling and will not stay running once it is warmed up. No codes. Replaced 02 oxygen sensor recently (codes was on), but will not stay running. Checked battery, alternator, fuel pump. I believe it is something electrical, but not sure. Any suggestions?
Does it run fine when it is cold? my dakota would stall in reverse no matter what and would idle fine in drive and park when cold. but when it was warm it would only idle in park. When i shifted it would stall and my problem ended up being a Crank Position Sensor(CPS)
I've been doing quite a bit of reading due to some problems with my 98 5.2l 4x4 and it sounds like you need a Crankshaft position sensor, ordered mine this morning from that major online retailer A***** for $63 for an actual Mopar sensor.
Trending Topics
I seem to remember there being a problem with mid 90's models (not sure if yours falls into this generation), but the splices under the PDC would corrode and cause hard starts and intermittent stalling. A friend of mine had to resplice everything recently (ended up trading it in shortly thereafter) and I *think* his was a 96.
I say replace all your sensors your truck is very old and its cheaper than any auto shop just dive in and replace them all it will cost as much as one trip to a shop... CORRET
Next tune up and remove the throttle body and clean check all vacuum lines for cracks
Keep the old sensors as backup
Best is to replace the sensors in steps this will help you find exactly were the problem was to begin with
Like all O2 sensors first then the all throttle body sensors so on so on
Don't forget about the Cat and muffler they can trash your performance and how it runs also
