fogs in stock location? need help
Old Dec 15, 2009 | 07:34 PM
willyb8's Avatar
willyb8
Default fogs in stock location? need help
i don't have fogs in the bumper but want to add some. what are some decent ones for under $100. also is the factory wiring already there just not the lights? is it hard to wire them so they come on when the lights are turned on with the factory headlight switch?
Old Dec 15, 2009 | 07:41 PM
RoaminGnome's Avatar
RoaminGnome
Well do you have a switch in the cab? Just pop your head under the bumper and check for the plugs.
Id ebay or junkyard for the lights. I saw a nice set of projector fogs for like $50- 60 shipped
Old Dec 15, 2009 | 07:42 PM
Josh Abels's Avatar
Josh Abels
should just be plug and play, as long as your switch has the feature for the fog lights, and check ebay for different ones, if you want oem check lmc truck or summitracing
Old Dec 15, 2009 | 08:31 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
that option might have to be turned on in the CTM, also i just had to buy a new fog light housing for my truck and the factory dodge ones from the dealer are 75 each. so for around 150 you could have the correct setup.
Old Dec 15, 2009 | 08:57 PM
thunder98110's Avatar
thunder98110
i am partial to piaas because i have a pair, but they run alot more than $100. wiring takes about 30 seconds, no joke.
Old Dec 15, 2009 | 09:48 PM
willyb8's Avatar
willyb8
switch only has the park and headlight.
Old Dec 15, 2009 | 10:11 PM
RoaminGnome
can ya pull it out a notch? only when the parking light or headlight it selected
Old Dec 15, 2009 | 11:17 PM
Josh Abels's Avatar
Josh Abels
kc hilites>piaa lol :P
mine cost 130 on ebay brand new in box, but like 200 from kc
Old Dec 15, 2009 | 11:19 PM
Josh Abels's Avatar
Josh Abels
if your switch doesn't have the fog pull out, you could always splice them into your parking lights or your low beams
Old Dec 15, 2009 | 11:37 PM
thunder98110
damn i got shafted $220, i should use ebay more often.
