1997 dodge dakota HELP! WANNA GO 5.2 TO A 5.9 WILL IT WORK????
Old Dec 28, 2009 | 01:34 PM
  #21
ewhetzel21's Avatar
ewhetzel21
thanks crazy 4x4rt those two drunks talking about captain crunch and captain morgan...what the fu$#$#@$k?!? And yes i can do it myself you idiots!!! Don't appreciate your advise and stay off the internet while driving lil man...lol
Old Dec 28, 2009 | 01:56 PM
  #22
darrelldubree's Avatar
darrelldubree
The 5.3 and 5.9 are twins on the outside. I am confident that they will swap out. If the comp. will not work, find a used one.
No problem.
Hope this helps
Darrell
Old Dec 28, 2009 | 02:11 PM
  #23
User's Avatar
User
Originally Posted by Crazy4x4RT
First of all stop the fighting or else I will close this thread.
Yes you can. If you are going from a 5.2 magnum to a 5.9 Magnum. Then yes you can. Very simple. Just swap in the long block with the harmonic balancer to the flex-plate. No welding or cutting or modifying of any kind. EVERYTHING WILL work. I have done it. EVERYTHING is the same! From motor mounts to oil pan to transmission bell housing. The only issue you may run into, is that the computer will not give you 100% as a stock 5.9 computer will. Maybe around 90%. And thanks to the sensors the computer will adjust the timing and fuel ratios to keep it good.
Depends on his tranny the 5.9 requires a little modification to run the 5speed, 46re no. Also who is fighting? The was was a ***** to start out with and then edited his posts, i was being sarcastic when i said cuz batman said so, 5.2 to 5.9 is not as easy as everyone claims and type of motor swap is not easy for everyone as you may think, also you have a gen1 this guy has a gen 2 which does change a few things.
Now i know why i left this place, over modded piece of **** forum. They fire the good mods like me because i stood up for what i believed at the time TOTM and Ram. Crazy chill out, don't turn into Pyro and Hammer be cool don't be a douche mod.
Also your truck is not an R/T FYI. Just saying...
1. I was not drunk
2. You sound like a 14 year old that just learned how to cuss.
3. And yes with the help of your dad and you handing him the tools "you can do it yourself"
4. That was a horrible comeback about driving and internet.
5. Funny how you cant stand up for yourself, till the mods showed up.
No problem.
Hope this helps
Darrell
And engine harness.
Old Dec 28, 2009 | 02:21 PM
  #24
batman13's Avatar
batman13
i was a bit inebriated yes.
but really, im just an *******.
welcome to the forum, i hope you enjoy your stay
*gag
*gag..
damnit i puked in my frosted flakes
Old Dec 28, 2009 | 02:57 PM
  #25
Crazy4x4RT's Avatar
Crazy4x4RT
So please be specific User! Why won't it work? Where is your proof? Resources? I know there is no difference in the motor mounts locations are the same. The stock computer can run the 5.9. Stock injectors can run it efficiently. Yes a 5.9 computer and injectors are best!
Old Dec 28, 2009 | 03:10 PM
  #26
95_318SLT's Avatar
95_318SLT
Actually, Crazy, even the injectors are the same between the two. The only three things you would need are the engine, computer, and the balanced flywheel or flex plate depending on the transmission. The harnesses are the same, the mounts are the same, everything else is the same. You could even settle for a 5.9 short block and put your 318's heads, intake, oil pan, etc. on it.
Old Dec 28, 2009 | 03:34 PM
  #27
Crazy4x4RT's Avatar
Crazy4x4RT
Exactly my point. User says there is more. I'm just waiting for his proof!
Old Dec 28, 2009 | 03:38 PM
  #28
Brutus's Avatar
Brutus
Hope all the threads dont end up like this one...
Old Dec 28, 2009 | 08:56 PM
  #29
ewhetzel21's Avatar
ewhetzel21
i just wanted to know if it would work...the trans. is auto. dont know if it s a 46re or what it is but its auto...i do appreciate the feedback from everyone though
Old Dec 28, 2009 | 09:03 PM
  #30
95_318SLT's Avatar
95_318SLT
Yes its a 46re. This is important... you need to use the 5.9L's flex plate! The 5.9L is an externally balanced motor whereas the 5.2L is internally balanced. The two flex plates are not interchangable.
