grinding noise
Old Dec 30, 2009 | 01:26 AM
kevindakota00's Avatar
kevindakota00
Default grinding noise
My truck is a 2000 2wd 4.7L auto. it seems to drive ok, but it makes a "grinding" noise that pulsates that is consistent with the speed of travel. the brakes where worn so i replaced them and the stabilizer links where bad so i replaced those. the noise remains. it is hard to tell where the noise is coming from in the cab but my educated guess is pass. front. the bearing has no 6-12 oclock play by the way, possible tranny? rear diff (noise up the drive shaft?) any ideas are appreciated.
Old Dec 30, 2009 | 01:47 AM
Independentfool's Avatar
Independentfool
did you replace the calipers when you worked on your brakes?
also, any play whatsoever in the bearings is bad. check the other side too.
Old Dec 30, 2009 | 07:38 AM
kevindakota00
i had not replaced the calipers, i have never seen calipers make a "pulsating" noise. the caliper did however have a small indentation cut into it the shape of the brake pad pass. and driver side, probably normal wear. anyway the pass side bearing is tight, the driver side does have some play in it but the sound does not appear to be from that side.
Old Dec 30, 2009 | 08:31 AM
stashum's Avatar
stashum
its hard to diagnose it without hearing it, but make sure your caliper bolts are tight. also check that the sheetmetal dustshield behind the rotor is not rubbing against the rotor(just bend it back). I'm more familiar with honda's than dodges(Honda tech for 5 years), and it is very common to accidentally bend that shield when removing the wheels
