front end problem CV/balljoints ????
Old Dec 30, 2009 | 04:37 PM
BoeingMan's Avatar
BoeingMan
Default front end problem CV/balljoints ????
Hi guys. Wonderng if anyone could help. Just started happening last month.
I have a 2000 dak 4x4 automatic V8 with 44k miles. Truck runs fine when I am rolling straight ahead. However, when I make a full right hand turn the truck wobbles slightly. The wobbling is similar to the wobbling you get when you engage the 4x4 on a dry pavement and start to make a turn. The wobbling is NOT as pronounced as that but SLIGHTLY similar.
I have not jacked up the car yet (way too cold outside) to check for ball joints or cv's, but as I describe it, can anyone pin this one down.
You guys helped me fix a rpm fluctuation problem in the past and hope you can help me fix this one.
thanks in advance.
Old Dec 31, 2009 | 02:57 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Tons of possibilities. Lifting it up and moving things around to see what has play is the only way. You could also take it to a shop and ask if they do free checks/ test drives.
Old Jan 1, 2010 | 12:23 AM
BoeingMan's Avatar
BoeingMan
thanks for the reply I do agree I need to jack this thing up
