I have a problem
Old Dec 30, 2009 | 07:39 PM
Rancidgore74's Avatar
Rancidgore74
Default I have a problem
As you can see, I have sufficiently rounded (or rectangled) out my bleed nut on my rear drum on the driver's side. I am completely stumped on removing it. It's rusted in and vice grips have not worked. Any ideas?
Old Dec 30, 2009 | 07:52 PM
wewanaplay's Avatar
wewanaplay
Replace the wheel cyl. they are relatively cheap. OR, Drill it, re-tap it, flush the hell out of it, and install abiggerone in it's place.
Old Dec 30, 2009 | 07:53 PM
wewanaplay's Avatar
wewanaplay
or if you can, try a little heat.
Old Dec 30, 2009 | 07:54 PM
batman13's Avatar
batman13
X2.. good luck
Old Dec 30, 2009 | 08:06 PM
Repo's Avatar
Repo
If you have enough room to still get a hold of it try heating it up with a torch and then it should break free.If you can not get a hold on the bleeder you will have to remove the wheel cylinder to get ot out and if you go through that just put a reman in!
Old Dec 30, 2009 | 08:11 PM
JBs DAK's Avatar
JBs DAK
Get a new one.
Old Dec 31, 2009 | 12:56 AM
Rancidgore74
I really appreciate everyone's advice, but it seems as if this has gone past my level of ability. I'm gunna have to bring it to someone. Thanks so much for your help.
Old Dec 31, 2009 | 02:07 AM
Ram_It98's Avatar
Ram_It98
you can also try using a grinder to get that octo shepe and use a smaller wrench and some pb blaster to losen it and brakedown the rust
