I have a 01 Dakota 3.9l v6 and i alway had trouble with the truck dying when it idles down. If i tap the accelorater and take it to about 1500rpm the truck wiil idle down till it dies. It starts right back and does not give any codes. Also if i am backing up a hill and cut the wheels hard it will kill the motor. Any ideas on wat could be the problem? Thanks
+1 on IAC. Be sure to handle it carefully and not drop it or you will need a new one. Clean the black crusty crud off the pintle end gently, with a shop rag sprayed with carb cleaner.
Jimmy
Try what they said. My truck has sometime stalled out while turning but only when in 4x4 I was planning on doing that but there is a boat in my way thawing out
