rear sliding window
Old Jan 8, 2010 | 11:55 PM
tallhamer88's Avatar
tallhamer88
Default rear sliding window
Some how i problem happen that my left rear window piece of the 3 piece slider broke and shatterd. now i was wondering do i have to replace the whole thing or just the that peice..
Old Jan 9, 2010 | 12:07 AM
moparman_2004's Avatar
moparman_2004
the whole thing
Old Jan 9, 2010 | 12:08 AM
tallhamer88
that blows..
Any idea how much that runs?
Old Jan 9, 2010 | 12:16 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You can just replace the center, if you can find a replacement. If not the a good auto glass shop can make one. Very simple. You do have to remove the entire window to replace the center. Or go to a junkyard.
Old Jan 9, 2010 | 12:19 AM
tallhamer88
its not the center is the side piece the center slider is fine its just the left side piece..before it splits to the slider.
Old Jan 9, 2010 | 12:31 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Same as before.
Old Jan 9, 2010 | 03:23 AM
moparman_2004
trying to pull the back windows is a bitch lmctruck has a replacement slider the whole window
Old Jan 9, 2010 | 11:15 AM
mightyminder's Avatar
mightyminder
If you do buy a new one . . .
CR Laurence has a cheaper one compared to lmctruck
You need to make an account, and I am sure the quality isn't as good.
But it is 80 bucks cheaper
Old Jan 10, 2010 | 11:04 AM
DennisCon's Avatar
DennisCon
DO NOT BUY CR LAURENCE!
We had one installed in my son's '01 Dak and it does not fit correctly - it is an external window (universal fit gasket), meaning it is not flush in the frame and leaves a big ugly (1/2") gap between the interior trim and the window. It ends up looking like the gasket was installed inside-out. Their installation guide instructs the installer to fill that big gap with windshield goo. The POS is noisy - sounds like driving with the doors ajar; and it looks like crap.
You will have to spend big bucks to get a good one.
Old Jan 10, 2010 | 11:10 AM
Papa Bo's Avatar
Papa Bo
just go to your local junkyard, i replaced my solid rear window with a slider this past summer, only cost me $35, its a PITA job but should only take you a couple hrs to take one out and clean it up then another hour to clean up the window frame and put it in.
