Crazy speedometer bounce
Old Jan 11, 2010 | 10:01 PM
dirtbagcfh's Avatar
dirtbagcfh
Default Crazy speedometer bounce
Need some help with my 97 dakota. 5.2, 4x4, stick...
Speedometer needle just started acting up. it will go from 40mph to 120mph, and stay pegged till i stop. Thought it'd be a bad ground so i re-did my battery terminals, but it still does it. I just did plugs, wires, distributor cap, and rotor too. Truck runs great, starts great. Just don't have a speedometer. Any ideas???
Old Jan 12, 2010 | 02:29 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Most likely a faulty speed sensor. Or wires to the speed sensor. I say replace it and see if that fixes it.
Old Jan 12, 2010 | 08:04 AM
bpark8824's Avatar
bpark8824
Yeah most likely a speed sensor. Mine did that for a few times and then I replaced the speed sensor. Did your ABS light come on? Sometimes that will come on if its the rear speed sensor over the rear diff.
Old Jan 12, 2010 | 03:56 PM
dirtbagcfh's Avatar
dirtbagcfh
no ABS light. ill replace the speed sensor. Is that a pretty cheap fix?
Old Jan 12, 2010 | 04:18 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Not so cheep. Maybe $100. Go to www.autozone.com and check.
Old Jan 12, 2010 | 05:17 PM
bpark8824's Avatar
bpark8824
No I paid like $30 for mine at Federated... That is the one over the rear diff. There are two. The other one is on the tranny. If you don't have an ABS light on its probably the one on the tranny.
Old Jan 12, 2010 | 05:38 PM
dirtbagcfh's Avatar
dirtbagcfh
Thanks guys, ill replace it tomorrow and see if it works!!!
