I tried the Meguires kit and yes, it did make an improvment but I wasn't all that impressed. I plan or steping over to some projector beams or something soon anyway.
i call them lenses but w/e.
first u need a hexdriver to loosen the blinker, and move it out a little.
then i used a long flat srew driver to release the clips.
2 on the top, 2 on the bottom, and 1 on each side i think. 6 clips total
the right way is to do it slow and not break anything. lol good luck
Anyone have a lead on adjustment screws for a '97. There's two or three long ones with a torx head and a short torx that holds tha corner marker. Mine are all f up. I searched the net but only found the whole assembly. Dealer says whole assembly too.
Just bought the kit and did the lens on my beater. Mind you, I'm not all too particular with the beater, so it's not perfect. But it made a huge difference. You can still see a slight shadow of the yellow haze, but again, huge difference. I like this kit better than some of the others I've used in the past. Using the drill makes it a lot easier.
