03 dakota Fog Lamps that go out constantly
Old Jan 19, 2010 | 09:37 PM
Schuey's Avatar
Schuey
Default 03 dakota Fog Lamps that go out constantly
ive been replacing my 03 daks right side fog lamp about 4 times now i keep thinking the bulbs are going out so i took the bulbs into my local autoparts store and they tell me its fine.. i swap the bulbs each side as well and they light up fine.. Left fog lamp works fine never had problems right works sometimes but mostly doesnt i dont see any frayed wires underneath and everything is stock factory installed lamps... anyone else had these issues ?
also its lovely winter time again and taking corners my heater blows out cold air.. only on turns.. radiator has fluid and just replaced water pump.. but it doesnt happen all the time
and lastly i think i once asked this question but i cant find the old post..
my check gauges light comes on when its cold out under 40 degrees but once i shut truk off and turn back on once its warmed up no light and nothing shows on engines codes.. dealer cant reproduce
any ideas?
Schuey
Old Jan 19, 2010 | 11:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
My guess is a wire issue. Sometimes they can be hard to find. Just test out to see if you have a problem with the positive or negative side then track it down.
You can check the codes your self. Check the FAQ in this section.
The heater problem can be an blend door issue. Or a clogged heater core.
