Tire Height
Tire Height
I have a 02 extended cab dakota that is stock. I understand if I change my tire size I will have to re calibrate my speedometer do to the rotation of the tires. What I would like to know is I am currently running a 31 x 10.5 15 tire I cannot go much wider because they will rub when turning but can I possibly put on a tire that is 33” for the height without rubbing on the suspension or the inner fender well?
Okay I checked out the faq page and noted that according to factory spec I should have a 2 inch lift for the tires that I have been running for the last 3 years. I have never had any concerns with rubbing in any of the conditions I have put my truck through.
So I guess I get out the tape measure and find out how much clearance I have and go from there. Thank you for the help.
this is a perfect example of lazy members just telling somebody to "check the faq"..because in his case the "faq" is wrong concerning his situation..im new here..but im a member of many other forums...and jesus christ its a FORUM! DEFITION OF FORUM: a public meeting or assembly for open discussion
if youre too good to answer somebody's question just go away instead of posting "CHECK THE FAQ" CONSTANTLY...
