View Poll Results: What do you think about the new Hemi motors.
They're Junk.
0
0%
Better than the old ones.
12.50%
I like the old one's better.
12.50%
The best Dodge Motor available today.
50.00%
Other Dodge Motors are just as reliable.
0
0%
Can't decide.
25.00%
Voters: 8. You may not vote on this poll
Dakota Hemi Swap!! With pics!!!
Old Sep 26, 2010 | 02:06 PM
  #91
00dakSport's Avatar
00dakSport
http://www.youtube.com/watch?v=h0YWvZqIrEo
dam. dam good
lsd in the future?
Old Sep 26, 2010 | 11:38 PM
  #92
Josh Abels's Avatar
Josh Abels
holy crap did u even have to stand on the brakes lol definitely in need of the lsd
Old Sep 27, 2010 | 10:32 AM
  #93
HemiDak-Quad's Avatar
HemiDak-Quad
No need for brakes.I Have a locker rear end,but even with posi-trak, it still spins off the line. I need some drag slick.
Old Dec 18, 2010 | 01:32 PM
  #94
HemiDak-Quad
Default 5.7 Liter Hemi Powered Dakota.aka:HemiDak-Quad.
"PLAY IT LOUD".. This is only the beginning..I'm looking for 6.1 Hemi Parts, Fuel Injectors, Intake Manifold,Throttle Body, Exhaust, Fuel pump, For starters..I want to eventually convert this little 345 hp 5.7 to a 490 hp 6.1 Ford Lightning EATER..
Old Dec 19, 2010 | 05:46 PM
  #95
EricBing's Avatar
EricBing
that is AWESOME! nice job
Old Dec 25, 2010 | 10:11 AM
  #96
brentfitz3's Avatar
brentfitz3
Wow nice work, that's pretty badass
Old Dec 26, 2010 | 09:42 AM
  #97
HemiDak-Quad
Update It's been 5 months now since I first started this Hemi and took it for a test drive..I have had to , Re-weld a broken exhaust clamp. Re-tighten my motor mount bolts.
Re-place the electric fan.and pull a dent.Someone Hit it with her car,while I was parked.
I haven't had any Major problems "Knocking on wood "- this truck rides - drives like a dream..I've outran 4 chevy's and 2 Fords. We figured out by marking out 1/4 mile down a back road,it will run 110 MPH..I'll be trying it on the track soon to get a time. I'll keep everyone posted once I start making the changes : Cam, Intake, Headers, Etc.....
Thank you to everyone who checks this post out ..And gives input...
Old Dec 26, 2010 | 12:55 PM
  #98
99-318's Avatar
99-318
Thats awesome man, Probably feel like you could do any swap after figuring out the wiring on that thing .
I gotta stock 5.2 in mine, 5 speed, I honestly pulled away from a dodge cummin 3500. Mind you I was a little past the red line... lol. got to 100mph fast though.
Old Jan 1, 2011 | 10:48 PM
  #99
HemiDak-Quad
yeah- I'm pretty proud of this truck.It'll look better once I do the airbrush work on it..
Old Jan 10, 2011 | 03:12 PM
  #100
HemiDak-Quad
I'm going to start posting PCM Pin-out's now...
Anyone doing a swap will need this info to do it..It took me months to gather this
Information online from sight to sight , gathering bits and pieces..
Now I'm going to put it all in one place..I hope it helps..
We'll start with The 4.7 Liter Dakota..This will also be the pin-out for some 4.7.L-Rams.
C-1 4.7 -2001 Dakota..
PIN#
#1 K93 (tn/or) Coil #3
#2 F18 (lg/bk) Fused Ignition Output..
#3 K94 (tn/lg) Coil #4
#4 K4 (bk/lb) Sensor Ground (-)
#5 K96 (tn/lb) Coil #6
#6 T41 (bk/wt) T-41 (a/t) Park Neutral sensor.
#7 K19 (bk/gy) Coil #1
#8 K24 (gy/bk) Crank Position Signal "sensor"..
#9 K98 (lb/rd) Coil #8
#10 K60 (yl/bk) Idle Air control #2 Driver..
#11 K40 (bn/wt) Idle Air control #3 Driver
#12 K10 (db/or) Steering Pressure Switch
#15 K21 (bk/rd) Intake Air Temp. Sensor..
#16 K2 (tn/bk) Engine Coolant Temp. Signal..
#17 K7 (OR) 5 Volt Supply (+)
#18 K44 (tn/yl) Camshaft Position Sensor "Signal"..
#19 K39 (gy/rd) Idle Air Control #1 Driver..
#20 K59 (vt/bk) Idle Air Control #4 Driver..
#21 K95 (tn/lg) Coil #5..
#22 A14 (rd/wt) Fused Battery (+) 12 v..
#23 K22 (or/db) TPS Signal..throttle psition..
#24 K41 (bk/db) 02-1/1 Signal..
#25 K141 (tn/wt) 02-1/2, Signal..
#26 K241 (lg/rd) 02-2/1 ,Signal..
#27 K1 (lg/rd) MAP Sensor Signal..
#29 K341 (tn/wt) 02-2/2 Signal..
#31 Z12 (bk/tn) GROUND (-)
#32 Z12 (bk/tn) GROUND (-)
C-2 4.7 Dakota...
Pin#
#1 T34 (gy/bk) 3.9/4.9 only- ..
#2 K26 (VT) INJECTOR #7
#4 K11 (wt/db) Injector #1
#5 K13 (yl/wt) Injector #3
#6 K38 (Gy) Injector #5
#7 K17 (db/tn) Coil #7..
#8 K88 (vt/wt) 3.9/ 4.9 only---
#9 K92 (tn/pk) Coil #2
#10 K20 (DG) Generator Field Clutch,..
#11 K54 (or/bk) Torque converter "Control"..
#12 K58 (bn/db) Injector #6..
#13 K28 (gy/lb) Injector #8..
#15 K12 (TN) Injector #2..
#16 K14 (db/bn) Injector #4..
#17 K24 (db/pk) Radiator Fan "control"..
#19 C18 (DB) a/c Pressure Signal..
#21 T60 (BN) 3.9/4.9 only- Shift solenoid..
#23 G60 (gy/yl) Oil Pressure Sensor "signal"..
#25 T13 (db/bk) Speed Sensor GROUND (-)
#27 G7 (wt/or) Vehicle speed sensor "Signal"..
#28 T14 (lg/wt) Output Speed sensor "Signal"..
#29 T25 (lg/rd) Governor Pressure Sensor "Signal"..
#30 K30 (PK) Transmission Control Relay ..
#31 K6 ( vt/wt) 5 VOLT SUPPLY.. (+) 5v...
