Pinion seal size?
Old Jan 28, 2010 | 01:58 PM
dodgemytruck's Avatar
dodgemytruck
Default Pinion seal size?
HELLO!
i've been filling up my rear axle with gear oil weekly because i have discovered that the pinion seal is toast. only problem with replacing it is that i have not a clue what size it is. its on a 2000 dodge dakota slt 3.9L 2wd.
im told i need to figure out the size of the "ring gear." so i guess that is the number i'm looking for. i was told by partsource that it could be 8 1/2, or even 9 1/2. or something else even?
any help would be greatly appreciated. thanks
Old Jan 28, 2010 | 02:19 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
The rear cover would tell ya. How many bolts does it have?
Old Jan 28, 2010 | 05:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
Like lghtngblt02 had said, look at the diff cover. If the looks round then its a 8 1/4, if its has sq corners then it a 9 1/4. Also can tell by how many bolts on the cover too.
Old Jan 29, 2010 | 06:36 PM
dodgemytruck
Thumbs up
i found out it is 8 1/4. thanks for the help
