wont start once warms up
Old Feb 4, 2010 | 07:52 PM
areed424's Avatar
areed424
Default wont start once warms up
The truck is a little rough to start, when cold. Once the truck gets warms it barely starts. Finally when the truck has been idle or running for anytime it wont start at all i have the timing set as good as i can any idea's? I just fixed a po303 cylinder 3 misfire, after injectors, wires, any thing would help.
Old Feb 4, 2010 | 07:54 PM
thunder98110's Avatar
thunder98110
well i don't really know, it doesn't really sound like an IAC problem but I would check that just to be eliminate sure.
Old Feb 4, 2010 | 08:07 PM
areed424's Avatar
areed424
thanks i'll check it out in the a.m..... could it be a starter issue, could the heat have any effect on the starter? or maybe the wiring??
Old Feb 4, 2010 | 08:31 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
As temperature increases so does the resistance in wiring, but i wouldnt jump right to getting a new starter. does it seem like the engine is spinning over at its normal speed? or is it faster or slower than normal?
Old Feb 5, 2010 | 10:24 PM
areed424's Avatar
areed424
Default ahh
Yeah the truck is alot slower when turning over even when cold just way more slow when warm.... have you ever herd of a tdc sensor, do dodge ever have issues with the tdc? all i can find under tdc sensor's are people with ricer's. please get back to me..
