Roll bar?
Old Feb 9, 2010 | 10:56 AM
Gundyy's Avatar
Gundyy
Lightbulb Roll bar?
I'm thinking of building my own roll bar located behind my cab with a row of 4 bright lights across. It'll be easier to just keep it black but that's fine with me. Would I have to cut a hole in the box to mount it to the frame? Or would it fit right down behind the cab? Also any other suggestions would help
Old Feb 10, 2010 | 02:00 PM
dodgeramguy85's Avatar
dodgeramguy85
Most roll bars just mount to the floor of the bed and not actally the frame. Only roll bars I had to deal with that mount to the frame is jeep wrangler but that makes sense since there is nothing else to protect you.
Old Feb 16, 2010 | 12:17 PM
Gundyy's Avatar
Gundyy
oh really? that's even easier... so as long as i can build it, make some mounting brackets i'm all set. cool. what if i had a box behind my cab though
Old Feb 16, 2010 | 02:51 PM
varsis's Avatar
varsis
mount to the top of the box rails... as long as your not using it for protection and it's more for lights.. it should be fine. I Tie my dirtbike down to there sometimes.
Old Feb 17, 2010 | 12:05 PM
Gundyy's Avatar
Gundyy
more for lights. in that case i don't need to weld it down, just bolt it in?
Old Feb 17, 2010 | 01:05 PM
dodgeramguy85
As long as it had 2 bolts for each leg then it will be fine just bolted most roll bars that are aftermarket have 4 holes for each leg but you dont need that many. This is the roll bar in my buddys ram 2 go to the bed floor and 2 go on top of the wheel well. and actually the front 2 legs only have 1 bolt each cause to go to the other side was too much of a pain.
