Need ideas for perfomance mods
Old Mar 17, 2010 | 10:20 PM
  #21
stompk's Avatar
stompk
I've got the 5.2
I've done the TB, 1.7 RRs and M1 intake w CAI and exhaust. didn't go with a chip because i have nitrous.
trying to decide what cheap, easy thing to do next.
any noticeable improvement from :
MSD 6A Ignition
MSD Coil
Taylor 8mm Wires
Originally Posted by User
4bbl M-1 Intake Manifold
52mm Holley Billet Throttle Body
1.7 Harland Sharp Roller Rockers
Mopar Performance .600 Lift Valve Springs
Built 46re
2800 Stall Converter
Stage 2 Tansgo Shift Kit
Mopar Performance Valve Covers
Mopar Performance Air Hat
Mopar PPH Headers (Ceramic Coated)
APS Custom Baffles
Full 3in Spin Tech Exhaust
Mopar Performance PCM
SCT Custom Tuner (Hemi Fever)
SCT Tuned PCM (swap out with perf. pcm when i need to)
180 Thermostat
Autolight 3923's
MSD 6A Ignition
MSD Coil
Taylor 8mm Wires
Deleted Clutch Fan/Shroud
Stock Electric Fan
Cal-Trac Traction bars
Slotted and Drilled Rotors
EBC Green Stuff Pads
any of that...
Old Mar 18, 2010 | 10:10 PM
  #22
hnter08's Avatar
hnter08
Just drop the clutch fan, iv had mine out as well as the shroud for months no problem.
Old Mar 19, 2010 | 11:05 PM
  #23
02 4.7 Durango's Avatar
02 4.7 Durango
Default efan and shroud
Ive seen this comment before and have always meant to ask, why do some remove the shroud when you take the clutch fan off, am I wrong to think it would help the air flow.
Old Mar 20, 2010 | 12:38 AM
  #24
MadisonDakota's Avatar
MadisonDakota
Yes. You're just pushing air in from the front now, no reason to keep it.
Old Mar 20, 2010 | 11:12 AM
  #25
hnter08's Avatar
hnter08
exactially with out the fan shroud is just a big ol piece of plastic that gets in your way. if ya pull the clutch fan tho id also remove the air dam to the left of the radiator to increase your air flow. Done know how that id just pull the fan on a 318, 360 either but with my little set up it cools just fine.
