Loose hub assembly
Old Feb 14, 2010 | 04:45 PM
USMC Dodge's Avatar
USMC Dodge
Default Loose hub assembly
The other day I was taking off the front driver side wheel and noticed that the wheel wiggle in all directions. I ruled out balljoints because the knuckle wasn't moving but it was the hub assembly itself. I figure that the wheel bearing had finally gone bad and it's time to change it. Is this a hard job to do and are there tips out there to help me out? I have a Haynes manual but it doesn't really explain how to do it.
The truck is a 1999 Dodge Dakota 4x4
Old Feb 14, 2010 | 06:29 PM
MrBlond's Avatar
MrBlond
its not hard if you have the right tools. the hardest part is all the rust i had to deal with. get a good punch or chisel and big BFH you will be fine.
this is what i followed to change out mine http://www.dakota-durango.com/forum/...ad.php?t=65393
get a sixpack and about a day its not that bad.
Old Feb 14, 2010 | 07:53 PM
Me&MyMopar's Avatar
Me&MyMopar
Using anti seize on the bolts when you're installing the new hub is also a good idea
Old Feb 14, 2010 | 08:22 PM
USMC Dodge's Avatar
USMC Dodge
Wow thats easier than I thought. Thanks for the tips and especially the writeup.
Old Feb 21, 2010 | 05:23 AM
macx's Avatar
macx
You can buy hubs with name brand (i.e. Timken) bearings at Rock Auto pretty reasonable, or hubs without name brand bearings for under $100. I recently had
'to replace my right front and didn't have lots of cash so went with a hubs from a place called BuyAuto, on ebay. So far so good. I think it has a 2 year warranty if I recall?
It's important to get the right torque on the big center nut on the shaft to 175 lbs. Too much and you can ruin your new bearing in a hurry. Use some anti sieze on the splines.
I did mine in less than an hour in the driveway in cold weather.
Good luck!
Oh, do NOT over tighten the bolts holding the brake caliper on!!! USE A TORQUE WRENCH!
Don't ask. :-( You need a metric hex 3/8" drive socket, forget the size. Cheap sets are available all over. PUt some anti sieze on those bolts, too, cuz the calipers slide on them.
Old Feb 21, 2010 | 12:28 PM
Independentfool's Avatar
Independentfool
x2 on getting a good brand name bearing like Timken. there are too many crappy chinese knock offs out there that fail way too fast.
