Knock Sensor?
Old Feb 18, 2010 | 07:03 PM
Danny52186's Avatar
Danny52186
Default Knock Sensor?
My 2000 Dakota V8. seems to have a lil knock im not sure what it could b kinda confused? what is a knock sensor and what is its purpose? also what other things cuz a knock? thnx aot
Old Feb 18, 2010 | 10:49 PM
chickenlights's Avatar
chickenlights
a knock sensor will be mouned in the block and its purpose is to detect a pre ignition or detonation problem.it produces an a/c voltage when it detects this. it will controle you ignition timing so that your engine will run as far advanced as possible which is where it makes the most power. i am not sure if the 4.7 have one though. i have the same truck and mine has a lifter tick when it is cold probly due to a sticky valve or lifter. it goes away when it is warmed up though.
Old Feb 19, 2010 | 12:05 AM
Independentfool's Avatar
Independentfool
well you are mostly right..
if it detects knock, it will retard the timing.
and yes the 4.7 has one.
Old Feb 19, 2010 | 12:28 AM
MadisonDakota's Avatar
MadisonDakota
He is completely right, what are you talking about?
Old Feb 19, 2010 | 10:48 AM
Independentfool
this article is written for my W, but the same principle should apply.
https://www.zzperformance.com/grand_...les1.php?id=20
Old Feb 19, 2010 | 11:12 AM
MadisonDakota
Read his post again, I know a knock sensor retards the timing. He says it runs it as far advance as possible without knock.
Old Feb 19, 2010 | 11:43 AM
chickenlights
same difference. as far ahead without knock or retards if there is a knock.
