squeek in the front end. hmm?
Old Feb 20, 2010 | 05:57 PM
fourpointseven's Avatar
fourpointseven
Default squeek in the front end. hmm?
Well, The past couple weeks i've been noticing a Funny *squeek* coming out of the front end of my dodge pick-up. Mostly on the drivers side, can't really stick my head out the passenger side window and listen but it could quite possibly squeekin on that side too. It only makes the squeek when im at low accel over small bumps/big bumps. I thought it was the shock Or bad control arm bushings But i oiled up/greesed the bushings but it seems like it didnt' work. So i parked the truck and turned the wheel left to right severl times and it's still squeeking. Seems like its getting worse and worse.
Im gonna take a shot in the dark and say its the ball joints.. It's only bad when im driving slow and the truck is taking travel Or parked and turning the wheel from left to right. Im confused? seems like something is Dry.
On a 04 Dodge dakota 4WD 4.7.
Old Feb 21, 2010 | 12:19 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Lots of possibilities. Since turning the wheel back and forth works, then get someone to move the wheel while you go down and find it.
