Just Bought Z-Max Kit..This Stuffs Great!!
Old Mar 12, 2010 | 03:52 AM
weeds1017mopar's Avatar
weeds1017mopar
Originally Posted by Eimer123
Just FYI you are not supposed to spray throttle body cleaner while the truck is running. You should remove the throttle body from the truck and clean it. If you do spray it while the truck is running there is potential for a fire. Also the engine may throw some codes and run like crap afterwords.
Oh I'm well aware of that, but thanks for the concern. I just don't care enough to take it all apart. I don't use alot at a time anyway. The only codes it will throw is MAF codes if it gets into it. I've had the truck for about 5 months now and do it once a month. Haven't had any trouble yet.
Old Apr 1, 2010 | 09:06 AM
deadbolt's Avatar
deadbolt
Ive also heard that it will clog the cat!!
Old Apr 2, 2010 | 02:18 AM
metalsrfr's Avatar
metalsrfr
ill just stick with my yearly seafoam treatment, and the Lucas upper cylinder lube it seems to work fine, and then of course the good ol reguarly schedualed oil changes with royal purple and a K&N filter.
