wont turnover.2000 dakata 4.7 4x4
Old Mar 1, 2010 | 05:23 PM
00kota-da's Avatar
00kota-da
Exclamation wont turnover.2000 dakata 4.7 4x4
Recently I was loosing 3rd&od gears. Followed by 1st&2nd.It came back as P845. Got a selenoid pac & throttle valve. Changed the valve assembly & selenoid pac as one unit. Replaced both filters.New gasket and the proper tranny fluid. Assembly went good. Went to turn over the truck.....nothing. All shift lights are on. Headlights, signals work. It doesnt read any codes. Any ideas guys.
Old Mar 1, 2010 | 07:34 PM
NYsteve's Avatar
NYsteve
Sounds like it doesn't think it's in park. will it turn over in neutral?
Old Mar 1, 2010 | 08:57 PM
00kota-da's Avatar
00kota-da
Question wont start 2000dakota4.7 4x4
hi NYsteve. Not startinh in any position from P-L1.I didnt go anywhere close to the nuetral switch.The trottle cable needed a good push to get the bracket back on.New battery.Connections tight. Guy I work with is in jail(buys me time using bosses truck)any ideas....Its my baby.
Old Mar 1, 2010 | 11:22 PM
NYsteve's Avatar
NYsteve
Fuses are all good? may be electrical, use a test lamp or multimeter to see if the starter is getting power when you turn the key. (this is much easier with 2 people btw) if no power work backwards toward battery looking for anything wrong. if there is power to the starter when you turn the key, you may need a new starter.
Old Mar 2, 2010 | 01:24 AM
00kota-da's Avatar
00kota-da
Default wont turnover 2000dakota 4.7 4x4
Thanks NYsteve.Ill try that tommorrow.When last running Friday it was good.Would that cause all gear lights to come on.
Old Mar 4, 2010 | 10:51 PM
00kota-da's Avatar
00kota-da
Angry 2000 dakota wont start.
turns out my tranny is pouched.when its in park on the shifter....its in some other gear in the tranny.
