Engine Height Help!!
Old Apr 30, 2005 | 10:10 PM
DakMan6704's Avatar
DakMan6704
Default Engine Height Help!!
Ok, so in order for me to get an intake for my truck, I want to verify if the guys at 360degreez are correct. If anyone out there has a 2WD Dakota with the 4.7, or the explicit knowledge of this dimension (not theory)....please let me know. I want to see if there is a difference in the engine height varies between the 2WD and 4WD as they claim. I dont believe it would, as it doesnt make sense from a manufacturing standpoint, but what do i know. Any help would be appreciated for myself and anyone else lookin for an intake from them. Thanks!!
Old May 3, 2005 | 01:08 AM
reconstrucktion's Avatar
reconstrucktion
Default RE: Engine Height Help!!
Can you give me more details? From which point to which is the measurement. . .
Old May 3, 2005 | 10:38 AM
DakMan6704's Avatar
DakMan6704
im guessing/hoping you have a 2wd dak? I will take some measurements and call them to double check thier points of interference. Then post what i have found. Thanks for your help!!
Old May 3, 2005 | 10:47 PM
reconstrucktion
Yeah i have an 01 4.7 let me know?
Old May 9, 2005 | 12:13 PM
DakMan6704's Avatar
DakMan6704
Ok, baseline measurements....the first one is off of the throttle body. from there, vertically, to the rear seal for the hood, is about 3 3/8 inches. another measurement i took was from the drivers side frame rail, right where the hardline for the brake mounts to go to the flexible line. From there up is about 19 inches, to the top of the throttle body. Let me know if any of this varies or any other info. Thanks!
