45rfe, 4.7 dakota tranmission problem
Old Mar 25, 2010 | 10:54 PM
Dakota16's Avatar
Dakota16
Default 45rfe, 4.7 dakota tranmission problem
I had the tranny oil and filter changed. I put the truck in reverse anytime, the shift is smooth, but when I put in drive there is a delay when cold. If the engine is warm it does not delay into gear. This had never happened prior to the oil change. I had a obd meter on it from a mechanic and no codes showed up. The mechanic had demonstrated putting in drive and reverse a few times continuously and there was definate hard, harsh shifting. With the obd meter, he got the truck programmed to shift back to normal and smooth. After the truck sat for a couple hours I put the truck in drive and it had a delay again. Does it just take time for the truck to understand there was a tranny oil change? Does anyone have any thoughts?
Old Mar 25, 2010 | 10:59 PM
thunder98110's Avatar
thunder98110
you didnt go to jiffylebe did you?
Old Mar 25, 2010 | 11:40 PM
Dakota16's Avatar
Dakota16
nope I did not.
Old Mar 26, 2010 | 11:13 PM
hydrashocker's Avatar
hydrashocker
FInd out if they installed the correct AFT+4 fluid?
Old Mar 27, 2010 | 10:06 AM
shadow_knows's Avatar
shadow_knows
The tranny in my 99 dakota is a NV3500 synchromesh and I purchased 3 quarts of Pennzoil syhcnromesh oil (& one Lucas tranny treatment 11.99 )from autozone at 7.99 a quart , it takes more than the manuals say to reach the bottom of the fill plug . It took 3.5 quarts , but was fully drained and flushed . I also pulled the shifter due to a leak & found both factory gaskets to be uselessly deteriorated . So knowing normally using silicone gasket sealant on trannys is a poor sealant . I used an effective approach of cleaning the center tin port deflector and all surfaces with alcohol , then micro-meshed the same areas then applied the high temp ultra red-orange permatex silicone gasket maker sealant . It has not leaked and the tranny has never been better
Old Mar 27, 2010 | 10:45 AM
Dakota16's Avatar
Dakota16
Does anyone think that if the garage used a non-mopar atf+4 fluid that this could be my problem with the slipping? Maybe the shop used a substitue atf+4 fluid.
Old Mar 27, 2010 | 11:08 AM
shadow_knows
Yes definitely I have a 2002 Chrysler Sebring and that's exactly what someone had done. Now that it has the Valvoline ATF4 no more problems
Old Apr 8, 2010 | 07:59 PM
Dakota16's Avatar
Dakota16
Default Solenoid Pack
It turned out I needed a new solenoid pack. It shifts smooth and have no problems to date with it. Thanks to all who helped out! Cheers!
