2000 Dakota 4.7L Overheating
Old Mar 29, 2010 | 11:49 AM
blkdak4x4's Avatar
blkdak4x4
Default 2000 Dakota 4.7L Overheating
Had a thermostat go bad and had to replace it, ever since I have not been able to drive more than 1mile without being in danger of overheating. I have tried 3 different thermostats, verified the rad is not clogged up and still cannot get the coolant to circulate, I have tried to burp the system repeatedly without success.
Parts replaced:
Thermostat x3
Waterpump
Upperhose/cap
Is it really this hard to burp the system once an airlock has gotten inside?
Old Mar 29, 2010 | 12:36 PM
alleymad99SLT's Avatar
alleymad99SLT
You try the water pump? Maybe it crapped out.
Old Mar 30, 2010 | 06:37 PM
blkdak4x4's Avatar
blkdak4x4
Water pump seems ok. Any other ideas?
Old Mar 30, 2010 | 07:25 PM
MadisonDakota's Avatar
MadisonDakota
Burp it, there is no way that a water pump is the reason it is overheating within 1 mile.
Old Mar 30, 2010 | 08:00 PM
dakota Iceland's Avatar
dakota Iceland
Default try this ?
remove the thermostat to see if car overheats after 1 mile, water should flow through where it should go , then put the thermostat back in . driving without a thermostat will cause your engien to run cold the whole time , so you should only drive with like that for a short distance 10 km or so . well thats my idea .
Old Mar 30, 2010 | 09:38 PM
00kota-da's Avatar
00kota-da
is the belt routing okay.is the heatercore plugged.does your electic fan work.do you have a blown head gasket(air bubbles coming out at rad cap).do you have the right mixture of coolant.
Old Mar 30, 2010 | 11:55 PM
blkdak4x4's Avatar
blkdak4x4
Thank you everyone for the ideas, here we go.
-Belt routing looks good
-Tried 3 Diff thermostats, verified they open.
- Not sure about head gasket, no bubbling at rad cap and no coolant usage.
- Coolant mix is good.
Heater core is suspicious, no heat to cabin and the return line is ice cold. Would this cause the total stop in coolant circulation in the system?
Thanks for the great feedback.
Old Mar 31, 2010 | 10:39 PM
00kota-da's Avatar
00kota-da
try disconnecting one side of heater hose.loop it back to the engine.dont plnch the line.is the engine oil topped up.
Old Mar 31, 2010 | 10:44 PM
00kota-da's Avatar
00kota-da
only other thing i can think of e brake sightly on or brakes binding.
Old Mar 31, 2010 | 11:14 PM
varsis's Avatar
varsis
Heater core shouldn't cause any issues. But if somewhere else is clogged up well that could be an issue. Also have you verified that your thermostat is the proper way? Maybe you put it in backwards...
Also check the hoses on each side of the rad running to the pump, make sure they are both hot. if one is cold there is your issue.
