What? huh????
Old Mar 31, 2010 | 09:20 AM
wewanaplay's Avatar
wewanaplay
Default What? huh????
Ok yall, I just read something that was a bit disturbing. Someone in here Staded that as a check for a blown head gasket to check for bubbling coolant at the radiator cap. I have been turning wrenches for years and have never heard this claim before and I can see the relevancy of this check but at the same time I can see where it could be B.S. as well. What's your opinion? Is this a reliable check for a suspected head gasket? I personally have seen a lot of bubbling radiator caps and have never even suspected any kind of head problem.
Old Mar 31, 2010 | 11:00 AM
tiger8522's Avatar
tiger8522
Okay after reading your post and having personal experience with a Honda that used to blow through head gaskets on a regular basis, this method can work. However the bubbling you get from a blown head gasket is different than what is considered normal bubbling on the oil cap. The color will also look different. For a more positive check you can also smell your exhaust fumes to double check the bubbles on the oil cap to confirm the blown head gasket.
Old Mar 31, 2010 | 11:04 PM
00kota-da's Avatar
00kota-da
they are VERY small bubbles
Old Mar 31, 2010 | 11:10 PM
varsis's Avatar
varsis
The sure gasket check way is a compression check. Go pick up a compression tester.
Old Mar 31, 2010 | 11:16 PM
00kota-da's Avatar
00kota-da
got one
Old Apr 1, 2010 | 12:08 AM
wewanaplay's Avatar
wewanaplay
Yeah, I got a compression tester and that is mainly how I've always checked too. When I read this i was led to believe this guy was checking by the RADIATOR cap, not the oil cap. just kinda threw me off for a min. Either way, I still need to run a compression check on mine soon. We had a lil episode the other day. I'm planning on doing a good bit of work next week when my intake and stuff comes in anyway so I'll run a compression chech between now and then and see wether I get the warm and fuzzy or hhave to consider pulling the heads and re-ringing it. She's got a lot of miles but Just runs too damn good to need much.
Old Apr 1, 2010 | 08:14 AM
rtspeedemon's Avatar
rtspeedemon
Yes checking for bubbles works well, have experienced many blown head gaskets on my Magnum so kwow first hand it works.
Old Apr 3, 2010 | 06:53 AM
Brutus's Avatar
Brutus
The air bubble in the over flow brings back when I had a 7M. The Toyota Supra was famous for blowing that on the inline 6, between #5 and #6. Kind of like a kid.....when you would blow air into the straw in your glass of milk.
