Shifter VERY slowly spins as I drive, but can't turn it by hand!
Anyone else have this issue? I drove the truck 450 miles this weekend and the shift **** turned about 120*. I can't physically turn/spin the ****. I think it's the actually shifter that's turning.
Am I the only one?!
Am I the only one?!
Haha, yeah I had the same thing with mine when I first got it. I thought the **** was turning and I couldn't turn it back and was confused why my gear pattern was know 90 degrees the wrong way... found out that the gear pattern is just a cap over the top of the screw that holds the **** in place and it turns on its own. Especially if you use your entire palm over the **** it will turn quite easy.
So don't worry, your transmission isn't going to fall on the ground or anything tomorrow or pull the shifter out grabbing 3rd lol.
btw on a side note, how much power are your cars making? They look good.
