Bearing hub assembly
Old Apr 20, 2010 | 01:24 PM
dodgeramguy85's Avatar
dodgeramguy85
Default Bearing hub assembly
I need a the front driver side bearing replaced and since you have to buy the whole assembly so instead of a 12.00 bearing I have to spend like 60 or more for one. Question is I found one on ebay but says for 99 00 will this still work with my 98? Already checked rock auto and its 99 what do you think?
http://cgi.ebay.com/ebaymotors/1999-...item35a8745d58
Old Apr 20, 2010 | 04:56 PM
MrBlond's Avatar
MrBlond
that hub is for rear abs, do you have front or rear abs? if you have front abs i don't think those will work..
Old Apr 20, 2010 | 05:34 PM
varsis's Avatar
varsis
I had a bunch of parts from my ifs left over but I threw them out a long time ago no one wanted it lol. I did put a new bearing on the one side though. That looks like the one I got or similar. And should fit up But if you have ABS, that will NOT work. There needs to be a speed sensor for abs.
Chris
Old Apr 20, 2010 | 10:36 PM
dodgeramguy85
Only have rear abs I know that for sure.
Old Apr 22, 2010 | 04:15 PM
dodgeramguy85
Ok well got everything i need today but I find that there is a flimsy ring of metal that goes around the cv shaft that is rusted out my question is can I leave it like this or does it need replaced to keep the water out?cReally I dont know how it can keep anywater out cause there is no seal or gasket I just need a second opinion before I put it all back together. Im REALLY strapped for money right now and having to buy anything else is going to make me totally broke.
Old Apr 22, 2010 | 06:59 PM
dodgeramguy85
Ok never mind I got it all figured out. Turns out that metal piece I was talking about basically acts as a dust guard it doesnt even sit on the steering knuckle. So I packed the edge full of grease to stop any water from coming in and really the job was pretty simple 7 of 10 on my scale hardest part was breaking the rust weld holding the hub on to the knuckle took a BFH and a chisel and about 45 min of my time.
