Radio and turn signals not working
I have a 2001 Dodge Dakota. The radio and turn signals stopped working. If I wiggle the key in the cylinder they will start working as long as I keep pressure on the key. When the weather warms up they start working again. I was thinking of replacing the ignition lock cylinder. Am I on the right track?
Any help is greatly appreciated.
Thankyou Steven
Thankyou Steven
Welcome to the forum...
Sounds like the key cylinder is worn out. I think the Haynes book gives directions on how to remove it and check its operation. Or maybe a locksmith could check it for you too.
Dakota's have 3 ignition power circuits on the igntion switch, and it sounds like the accessory power feed on yours is losing power due to a bad connection in the key cylinder. I have heard and read about other Dakota's having the same problem. My own ignition key is pretty sensitive like that too.
Jimmy
Jimmy
