cheap front lift?
Old May 4, 2010 | 11:40 PM
ZAKMAN's Avatar
ZAKMAN
Default cheap front lift?
i wanna lift my truck and was wondering if there was any way i could lift the front 3-4 inches for cheap cause im going to flip the axle and spring on the rear so itll be spring on top of axle instead of vice versa and dont know the best way to lift the front its a 98 dakota 2wd
Old May 5, 2010 | 12:22 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You can add coil spring spacers for the front. Get about 2in for $20.
You can buy a body kit 2-3in $100-200. Thats not a bad price. Or build your own. Buy some thick wall tubing, then cut it up and buy some longer bolts.
Check the FAQ in this section for tons of lift Ideas.
