What size rims is equivilent to a 31" tire?
It all really depends on what size rims you can find with our bolt pattern and what size tire you can find to go on it! Keep in mind that not all possible sizes are available. But once you find a set of wheels, here is how to determine what size tire to put on it...
The first number is the section width of the tire in millimeters. This is not the bead width nor the tread width, this is the width of the widest part of the tire.
The second number is the aspect ratio. This is a ratio of the height vs the width. This number as a percentage of the first number gives you the sidewall height.
The third number is the bead diameter (rim diameter) in inches.
*NOTE* 25.4 millimeters = 1 inch
Example) 235/75/15
Width = 235mm = 9.25". Height = 235*(75%) = 176.25mm = 6.94"
Total diameter = (6.94*2) + 15 = 28.88 inches
Converted to standard size, this is a 28.88 x 9.25 x 15 tire.
Example) 235/75/15
personally not a good choice on these trucks they only look good stock or lifted. Just to give you an idea here is my buddys 26's on his titan cost him about 1,500 per wheel
