Spark Plugs
Old May 20, 2010 | 01:10 PM
Lee Snow's Avatar
Lee Snow
Default Spark Plugs
How hard is it to change the spark plugs on a 2000 4.7L? Without having a whole lot of car know-how... lol
Old May 20, 2010 | 02:43 PM
MikeCzipri's Avatar
MikeCzipri
Not sure about the 4.7L...but I just changed the plugs on my 3.7 the other day and I have been told that the 3.7 is basically the same engine as the 4.7 with 2 cylinders chopped off. IT wasn't necessarily hard, but it was different. MY engine (and probably yours too) doesn't have plug wires, it has these weird little spark-plug individual distributor things on each plug (I have no clue what they actually are, but that's what I call them). All you need is a deep socket spark plug socket and I think a 10mm socket to remove the plug distributor type things. Just unplug the electrical clip from the distrubutor things, unscrew the 10mm nut, and pull the distributor thing off. The spark plug is down in the hole where the distributor thing was.
That wasnt a great description I know, but maybe someone else will chime in here and make it a little easier to understand. Really, its not hard at all. Just kind of weird.
Old May 20, 2010 | 03:57 PM
Lee Snow's Avatar
Lee Snow
Well I have the spark plug socket and all that. I just want to know if it'd be possible for me to do it myself instead of paying 90 in labor. I could do alot more with that 90 dollars lol.
Old May 20, 2010 | 05:03 PM
dodgeramguy85's Avatar
dodgeramguy85
If you can turn a wrench you can do this no way in hell I would pay someone to work on my truck.
Old May 20, 2010 | 05:43 PM
Lee Snow's Avatar
Lee Snow
sweet! lol thanks
Old May 20, 2010 | 09:17 PM
thunder98110's Avatar
thunder98110
easy. it was the first thing i did to my truck, first car maintenance i ever did. that was just a year ago now ive done crap ton more. but just make sure nothing falls into the hole when u remove the old plug and gap them good.
Old May 20, 2010 | 09:40 PM
00dakSport's Avatar
00dakSport
90 bucks is borderline rape man lol. do yourself i did mine for like $15.
take a shop vac out first and get all the sand a stuff off the top cause you
don't want anything droping in your engine.
Old May 20, 2010 | 10:04 PM
Lee Snow's Avatar
Lee Snow
one of the plugs is under the AC lines... should I move them or will it hurt it?
Old May 20, 2010 | 10:10 PM
thunder98110
there is a clip on both sides that hold the metal pipes in place. if thats what ur talking about. my clips broke off but still holds it in place.
Old May 20, 2010 | 11:20 PM
rpowell's Avatar
rpowell
Yeah just remove from clips and then you can jam a socket extension right between them, at least thats how I did it.
