Transmission Problem
I dropped the pan from the tranny to change the filter and noticed some small pieces of what looked like clutch material. Since I replaced the filter and fluid, I have noticed that the transmission will now let the engine rev about 200-300 rpm before it shifts now. I thought that maybe I didnt put enough tranny fluid in, but I checked it last night and today after driving the truck for awhile and it is fine. This a sign that the trans needs rebuilt? With the engine revving a little between shifts, is this a sign of the torque convertor going out as well? I will be doing the rebuild myself, and I would hate to put it all back together just to find out the tourqe convertor or the control solenoid is bad. Any help with suggestions would be greatly appreciated.
it sounds like its slipping. I dont care what anyone says...anytime you open the tranny to air, IE a flush or drain, you're opening a can of worms... ya dodge says flush it...but screw that... I work at Midas as a tech, and we try to avoid doing flushes for that very reason. Its a sealed system and you're exposing it to the elements. The best way to service a tranny is with a fluid exchanger. you change out ALL the fluid and dont expose any of the systems to the elements. we usually tap in the cooling lines on the radiator and exchange the fluid that way. tranny pump is running into the machine and machine is pumping new fluid into the system...all fluid gets exchanged this way. a drain and fill by pulling the pan is asking for trouble IMO... but from what you've said it sounds like its slipping. any CEL?
So far I havent seen a CEL come up, but who says it wont. Who sell's the rebuild kit for $150? The cheapest I can find them are $245 with shipping. So far it actually feels like it is shifting better, but it still isnt up to par. So, within the next 2-3 weeks, I will be getting a rebuild kit, tourqe convertor, and maybe a control solenoid just to be on the same side.
I just had about the same problem with my 2000 Quad 4.7. Changed fluid and filters. Bought the filters at O'Reily's. Let the truck sit for over a day and when I put it in gear it wouldn't move unless I reved it up a little. Took it to a trans shop and they couldn't see anything wrong. They swapped out both filters and the seal for the pancake filter. They got the filters from Dodge. Everything has been working great since then. The guy said that sometimes the check valves in the after market filters dont work the way they are supposed to.
