02 Dakota CC; will plastic bedliner from 08-09 Dakota fit?
Old Jun 2, 2010 | 11:57 PM
UncleStu's Avatar
UncleStu
Default 02 Dakota CC; will plastic bedliner from 08-09 Dakota fit?
Just what the title says: will a snap-in plastic bedliner(Mopar, I think) from an 08-09 Dakota CC 6 1/2 ft bed fit my (brand new to me!) 02 Dakota CC SXT? I suspect not- the only dimensions I've found so far show the 05-10 bed to be about 1" longer at the floor, and just a bit wider between the wheelwells.
Old Jun 3, 2010 | 12:05 AM
crateampsrock's Avatar
crateampsrock
If im correct, the beds are different sizes. liner should be short. plus you also have to take into consideration, the mounting brackets in the bed, fender wells, and the inside body molding in the bed... get a do-it-yourself spray in... would look better and last longer. and not that expensive...
