my new ride
Old Jun 13, 2010 | 06:28 PM
ayoung101's Avatar
ayoung101
Default my new ride
finally got one after about 3 months of active searching and test driving a 1/2 dozen or so. got a 2000 quad cab 4x4 with a 4.7. pretty good shape! couple of bumps and bruises (it IS a 10 year old pickup truck, afterall), but nothing to worry about. no rust anywhere (surprising for michigan!).
Old Jun 13, 2010 | 06:34 PM
ayoung101's Avatar
ayoung101
got a few things i gotta do to it.
1. got to replace the smallest/cheapest truck tires ever to be put on a 4x4 truck! luckily i have a good set of BFG AT's that happen to be the same size rim so i can just swap them in and i'm good to go (i'm pretty sure i got enough clearance).
2. got a pretty good power steering leak going. the previous owner said he already replace the PS pump, but the fluid is definitely coming from the PS pump area, so i dunno. line maybe? i figured i'd replace the line and the pump both at the same time. i've heard this is a common problem, any suggestions/words of wisdom from the experienced? any good writeups on the site?
3. got a noise coming from the front left, i'm suspecting a wheel bearing, but it could be tire noise (i'll know for sure next week when i get the new tires put on). i've heard this is a common problem, any good writeups on this?
4. i have a tape deck installed in it. a TAPE DECK. haha, that's just unacceptable.
Old Jun 13, 2010 | 06:42 PM
Me&MyMopar's Avatar
Me&MyMopar
You're right about the tires, they need to go, and about the power steering pump, make sure you fill it with ATF +4 transmission fluid, and not power steering fluid. I made that mistake arleady with another truck. On cold mornings, the pump would groan for a few seconds, and the steering wheel was locked in place during the groaning. Just an FYI if you didn't know about the proper fluid.
Old Jun 13, 2010 | 07:01 PM
thunder98110's Avatar
thunder98110
how many miles?
Old Jun 13, 2010 | 07:09 PM
MadisonDakota's Avatar
MadisonDakota
Judging by the headlights, i'm guessing 120k plus.
Old Jun 13, 2010 | 07:13 PM
thunder98110
lol really? it all depends on weather. my headlights look 10times better than this new civic in my parkinglot.
Old Jun 13, 2010 | 07:36 PM
SpencerS's Avatar
SpencerS
as for the power steering pump leak, check the lines and the mesh screen inside the reservoir. if it has a substantial rip like mine did you will need a new reservoir.
Old Jun 13, 2010 | 08:04 PM
ayoung101's Avatar
ayoung101
ha, it's 150k. how could you tell by the headlights?
Old Jun 13, 2010 | 08:06 PM
ayoung101's Avatar
ayoung101
good to know. i never would have checked the reservoir. i can only see so much as is. i'll know more when i tear into it.
Old Jun 13, 2010 | 08:36 PM
MadisonDakota
They start to show age around 90-100k, and it looked like they were on there way to needing replacing/buffing.
I was guessing 140k, but I'd rather undershoot a little.
