POSI and 4:10 Gears
Old May 16, 2005 | 10:15 PM
duelsxt's Avatar
duelsxt
Default POSI and 4:10 Gears
I just got a POSI and a set of 4:10 Gears for my 2000 3.9 V6 Dakota. How much do you think this will help in giving this slug a new pair of *****. I am also going to put a shift kit in it very soon. The mechanic said that he had one just like it and it would BARK second gear even with the POSI. Is this possible...
Old May 16, 2005 | 11:45 PM
Flywheel's Avatar
Flywheel
Default RE: POSI and 4:10 Gears
Its possible, depends on your mods, etc.
Old May 17, 2005 | 02:01 AM
reconstrucktion's Avatar
reconstrucktion
Cool! How much did the posi cost you? whered you get it? (if you dont mind me asking)
Old May 17, 2005 | 03:33 AM
Redneck2345's Avatar
Redneck2345
it is extremely possible! 4.10 is a steep gear for a dakota and it would be really torquey with just those gears. The dakota is fairly light and should have a good power to weight transfer making for negative traction on most surfaces (you'll burn the **** outta your tires!) all the shift kit does is hold the gears longer so you get a higher rev and than it gives it a harder shift. its all possible though
you may want to try a cold air intake and maybe a free flowing exhaust to get some more ponies out of your 3.9 to!
Old May 18, 2005 | 12:50 AM
duelsxt's Avatar
duelsxt
I got mine through a trade. But there was one on eBay for 165.00 and the same guy had 4:10 s for 90.00 I think its a great deal.
