efan cfm requirements
Old Jun 26, 2010 | 09:42 PM
SpencerS's Avatar
SpencerS
yea, mine almost overheated when i was driving and had to drive at quite a incline up a mountain, luckily it droped off or else i would have pulled over. It was pushin 230 before it droped off. and the a/c was on.
that was in 90 degree weather as well
Old Jun 27, 2010 | 01:06 PM
thunder98110's Avatar
thunder98110
Originally Posted by Independentfool
im guessing you've removed the fan clutch? if so, adding an additional e-fan would be good, and it wouldnt have to be too big either.
hell i bet the e-fan i have would be good enough.
how did you mount yours?? i'm totally stumped on how i should install it. i cant get the stock one off the bolts are rusted/stripped in place so thoes mounting points are useless. i could do the radiator straps but i hear thoes will damage the fins.
Old Jun 27, 2010 | 02:28 PM
Independentfool's Avatar
Independentfool
mine came with nylon zip ties that go thru the rad. Sure you tweak a few fins but its no big deal.
Mine didnt have a e-fan stock so i cant help you on that regards.
Old Jun 27, 2010 | 02:40 PM
thunder98110
ok well then i wont worry about it. by far the easiest way to mount it.
