power door lock question
Old Jul 4, 2010 | 09:51 AM
Commodore's Avatar
Commodore
Default power door lock question
Is there a way for me to defeat the auto door lock function incorporated into the keyless entry system [once the truck is under way] or is it a dealer only re program visit? The fewer 'Nanny's' in my vehicles the better.
RB
Old Jul 4, 2010 | 10:21 PM
01SilverCC's Avatar
01SilverCC
You should be able to turn off rolling door locks this way:
1. Sit in the truck and close all doors. Be sure all the doors are unlocked.
2. Turn the ignition key from the OFF position and the ON position 4 times. On the 4th time, leave the key in the ON position. Don't start the engine.
3. Within 30 seconds of leaving the key in the ON position, press the door lock switch on the driver's door to lock all the doors.
4.The door open chime will sound one time to let you know the rolling door lock feature has been turned off. Remove the key from the ignition.
5. Follow this same procedure if you ever want to restore the rolling door lock feature.
Jimmy
Old Jul 5, 2010 | 07:53 AM
Commodore's Avatar
Commodore
The essence of good automotive forums is quick knowledgeable responses to questions. I wonder how many forum members, beside me, will be following your instructions today?
Thanks Jimmy
RB
Old Jul 5, 2010 | 08:14 AM
McNasy's Avatar
McNasy
im gunna give it a try. i always just lived with it. thanks silvercc.
Old Jul 5, 2010 | 01:41 PM
01SilverCC's Avatar
01SilverCC
YW. It should work for any Dakota from 01 thru 04 that has electric door locks.
Jimmy
Old Aug 21, 2013 | 04:25 AM
Medic5009's Avatar
Medic5009
I have done that 2 different times already, it seems to work for that time but the next time I get into the truck it locks when I start rolling again.
