99 Dakota 5.2 fuel pump keeps running
I just bought this V8 Dakota SLT with 150,000 miles. Ran perfect for 2 months, Here is the problem, Two weeks ago I went to start it and battery was dead. Replaced the battery, two days later the battery was dead. Long story short, the fuel pump was running all he time, I removed the fuel pump relay, and it kept running, I hit the tank, and it quit. So for a week I would remove the fuel pump fuse every time I parked it. Today I went to start it and the battery was dead, I listened and the fuel pump was running, (WITH THE FUSE OUT). What would cause the fuel pump to continue to run.
I checked the wires, and the wireing harness was pinched between the plastic gas tank seam and the frame. Problem solved. Thanks, Crazy4x4
